P0056 LR3 2005 code
Old Jul 16, 2015 | 04:20 AM
a_wick_2010's Avatar
Default P0056 LR3 2005 code
This is what I got from my LR3 2005, any idea what to do with this
P0056 heated oxygen sensor heater control circuit (bank 2, sensor 2)
It's normal or dangerous stuff to leave it as is?
Old Jul 16, 2015 | 07:11 AM
cmb6s's Avatar
I can't remember off the top of my head which side is bank 2, but sensor 2 should be one of the downstream oxygen sensors. You can try replacing the sensor and see if the code goes away, but there are many times where the problem may be something else and since the oxygen sensor lies downstream in the exhaust, it just catches other things that may be wrong.
Old Jul 16, 2015 | 08:39 AM
Jagfixer's Avatar
Anytime an engine codes, is not normal. The system has a fail somewhere and is telling you it needs looked at. O2 sensors also warn that you may be ready to destroy a very expensive catalytic converter. Sometimes a reset and a fuel system flush will help, but I do not know the miles or how you drive and the sensors are a 60K-100K maintenance change.
Old Jul 18, 2015 | 12:07 PM
Dear All
Which replacement recommended then for this sensor, this car (left hand drive) already run 193,000 kms.
For example
Amazon.com: Denso 234-9075 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive Amazon.com: Denso 234-9075 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive
It's mentioned upstream right
Another similar product mentioned downstream right
which one is correct one?
Thanks
Old Jul 19, 2015 | 09:05 AM
unseenone's Avatar
mtate315
Aug 2, 2024 08:26 PM
angrylobster
Jan 4, 2024 12:40 PM
nh9095
Jan 14, 2019 12:36 AM
jpclass
May 23, 2013 07:34 AM
sayeedA
Nov 15, 2011 11:02 PM
