View Poll Results: Have the same or similar issue on my LR3 or LR4
Yes
80.00%
No
20.00%
Voters: 5. You may not vote on this poll
P0116-24 Coolant Temp Sensor fault historic. LR3 2008 V8
Old Aug 23, 2021 | 05:03 PM
CaptainKhan's Avatar
3rd Gear
Default P0116-24 Coolant Temp Sensor fault historic. LR3 2008 V8
I was driving and stopped in traffic on a slight hill at 70degF nice cool day engine wasnt quite warmed up yet after 7min driving. Fault hasnt occurred before.
Next thing i know the engine cuts off. On restart terrain options not available and shifter stuck in F fault mode (which means the manual sport mode select options are not available and terrain response cannot be selected). The car is fully drivable but with limited gears.
Upon parking and cycling the ignition a few times and turning on off the engine a few times, 3-5, pulling the key out putting it back in faults disappear.
So i ran the codes and the coolant sensor thats installed in the thermostat (and which i had just replaced a year ago), could it be causing issues of engine just cutting out, or misbehaving?
The other lost communication faults can all be ignored typical LR3 message spam.
1. battery voltage is good and its new
2. alternator is good and new
3. all the grounds i redid a year ago and are clean corrosion free, plus no other electrical issues experienced in a year
4. the fact that the fault can be reset means its intermittent and situation dependent (voltage, temperature, quantity, pressure, current, incline on the road (since i was at a stop at zero speed) etc)
5. thermostat has not failed open since its new and it heats the inside of car
6. coolant and oil level is good
7. car raises and lowers on air suspension normally and no airstrut leaks
8. car locks unlocks normally and have already replaced the hood switch, the brake switch
Any ideas?
Old Aug 23, 2021 | 06:13 PM
If it's disconnected the car will not start. If running it will be absolutely terrible running, loosing power and cutting out. So a fault with it could cause drive-ability issues
Old Sep 6, 2021 | 04:29 PM
steevo67's Avatar
I've got that fault also. Can't figure out what it is. The gauge on the dash reads correctly and the engine runs fine.
Old Sep 7, 2021 | 07:38 PM
3rd Gear
Default Answering my own question so others can profit.
Figured out the engine turning off or not starting issue that appeared randomly one day on my Landrover LR3 2008 V8:
1. i replaced the coolant sensor but that didnt make a difference.
Solution: the engine relay - go figure. relays dont fail like light bulbs so when they fail its more of a sporadic contact closes or opens while driving situation, in my case for some reason the relay must have disconnected my ECU just so, hence the engine switches off or doesnt start, $20 fix, put in a new engine relay, i think they are 40-60 amp not sure, also i went through the engine fuse box and cleaned the contacts of all relays and all fuses just to be on the safe side and i havent had any issues for a couple days now, crossing my fingers, if they dont recur after 2 or more months then i resolved the intermittent fault (i switched the R9 window heater relay with the R6 engine electrical relay);
link to relay: <https://www.roverparts.com/electrical/relays-flashers-connectors/YWB500220G/>
Old Sep 8, 2021 | 04:14 PM
DakotaTravler's Avatar
Not to mentions relays are solenoid driven. Solenoids do "burn out" and get weak, hence the failure of the transfer case solenoid or when rebuilding a suspension valve block does not work but replacement does. Relays could almost be a 10 or 20 year maintenance item, just replace em all. They are just bog-standard relays after all.
tck1979
Jul 9, 2021 11:55 AM
Disco41989
Sep 12, 2019 03:12 AM
Saph
Mar 30, 2015 10:01 PM
hournet562
Feb 4, 2011 04:28 PM
