p0128
Old Feb 15, 2015 | 07:28 PM
TOM R's Avatar
Default p0128
Got this last night, engine gets to temp, it is cold as hell out though, cleared it will see if it returns
Basicly says engines taking too long to reach temp or not reaching temp
Low coolant, stuck on fan, bad thermostat, bad temp sender
Old Feb 16, 2015 | 07:01 AM
thorgal's Avatar
usually means thermostat stuck open .Replace it and you should be in god shape.
Old Feb 16, 2015 | 08:09 AM
TOM R's Avatar
Will do, just the thermostat and oring or the whole assembly? Since these are prone to break right?
Old Feb 16, 2015 | 09:40 AM
TOM R's Avatar
As usual amazon best price, $29 thermostat , o ring shipped!!
Old Feb 16, 2015 | 12:31 PM
thorgal's Avatar
That is a great price.
I don't know how much miles you have on yours, but my thermostat housing cracked at manifold , so I replaced the whole thing.Came with thermostat already installed inside.
Old Feb 16, 2015 | 01:44 PM
TOM R's Avatar
around 55k miles? I saw someone makes an metal replacement
Old Feb 16, 2015 | 03:42 PM
thorgal's Avatar
My housing cracked around 115 000 miles , so you should be fine for while. did not came across a metal replacement yet.
Old Feb 16, 2015 | 03:57 PM
TOM R's Avatar
Sorry not the housing its a bleeder t in metal
http://www.jewellamberoil.com/sales/...roducts_id=278
Old Feb 16, 2015 | 06:44 PM
roverguy7's Avatar
T-stat failure on this is usually the seal on the t-stat itself, rubber tears and allows coolant to bypass the t-stat. Check the seal when you take it out, if it is in good shape, you might be looking at a failed OCMV.
Old Feb 16, 2015 | 07:20 PM
TOM R's Avatar
Whats a Ocmv?
