P0128 code keeps coming back
The check engine light keeps coming back on and every time I run the odb it comes up with p0128 I already changed the T-stat and ect sensor now I'm at a lost on what else it could be also my temp gauge on the dashboard never goes past the quarter mark and help would be greatly appreciated
My temp gauge didn't go past 1/4 mark and luckily I had a ultragauge to show my real time engine temps which was around 140(LOW) when it should actually have read around 195, I bought a new t stat installed it myself (easy job/under 20 min) and everything is now running smooth and at normal operating temps. I would open up the tstat and check it yourself. if you have any questions you can pm me.
A lot of the time the rubber on the t stat will rip or come undone which allows the coolant to pass through. You won't have coolant leaking out but leaking pass the seal within the tstat housing, hence no visible coolant leak.
As for the needle not moving, some vehicles will disable the temp gauge if the P0128 is current. Of course, the P0128 sets when the engine won't warm up fast enough, so the temp gauge could be telling you the truth as far as engine temperature. So what could cause a repeat P0128? Faulty new thermostat, or your mechanic thought you would be better without a T-stat.
You won't know until you take it back out.
Yea she's going back this morning it might just be the faulty t-stat cause I sat there with him and watches him put it in so ill just take it to the dealer instead of letting these individual mechanic shops look at it hopefully the dealer can work their magic
Well land rover finally got it thermostat was installed wrong there's a little metal nub that's suppose to stay in the housing apparently he threw it out with the old T-stat serves me right for not coming to land rover first
