pcv
Old Feb 25, 2019 | 06:55 PM
Andrew Herrington's Avatar
3rd Gear
Default pcv
Ok quick rundown. Just bought a lr3 I had a disco 2 before .got a lean code on both banks. So I started with a filter change and maf sensor. Still there. Engine runs and sounds fine though. Changed pcv. New pcv sucks oil and runs horrible. Returned it and got another. We once again sucks oil smokes bad. It will run fine with the old pcv which is not clogged or anything. When I changed the first pcv. I reset codes and everything. Even did the hard reset. It ran great half a day no code or nothing then bam sucks oil and a code. Any suggestions?
Old Feb 26, 2019 | 10:19 AM
DavC's Avatar
who are you getting these PCV from? Dealer?
Old Feb 26, 2019 | 06:09 PM
3rd Gear
I got them special order through O'Reilly auto parts. Can't tell Abit of difference in any way from any of them look wise flowwise anything
Old Feb 26, 2019 | 07:04 PM
houm_wa's Avatar
Default Only difference...
...is that it doesn't ******* work!
You might have to go to the dealer or maybe Atlantic British or Lucky8.
Old Feb 28, 2019 | 11:00 AM
AtlantaViking's Avatar
Also, it really helps to know which engine you have...
Old Feb 28, 2019 | 04:19 PM
DavC's Avatar
presuming he has the 4.4 V8, just go get a genuine PCV. They aren't too expensive.
Old Mar 1, 2019 | 09:29 AM
3rd Gear
It is the 4.4
TexasRover1
Apr 30, 2021 11:29 PM
greenwood
Apr 10, 2019 04:56 PM
AtlantaViking
May 20, 2018 10:13 PM
Kilgore Trout
Dec 13, 2014 03:25 PM
humroot
Aug 26, 2012 08:40 PM
