Pinion Seal or seal from transmission?
Thanks! I have not checked for play. Only photos and doing a parts list. good to know I can grab the bearing without having to pull the case.
You need to break down the entire diff to change the bearing. At that point its a full rebuild.
rsvrman (07-10-2019)
Appreciate the info and sharing the knowledge!
And I'm far from an expert. Farm Kid > Worked at Ma and Pa's mechanic shop for 4 years (20 years ago)> On off shade tree w/ youtube assistance. I can tear into most things car related, but stop short of inner transmission work or lower end on engines. I've done it, but always had a guide. What I lack is the subject matter expertise per vehicle, which is where forums and individuals show their wealth. (Keep pulling on this piece for an hour, not knowing there's a hidden snap ring behind this corner you wouldn't have thought to look.) Been there done that. An expert shares 2 mins of his expertise and all is good. Hopefully along the way I can also share what was good and bad. Plan to journal the parts I'm replacing and document their longevity. Some are OEM some are not.
