crankshaft Seal install
Old Jan 27, 2013 | 01:38 PM
2Much_DISCO's Avatar
6th Gear
Default crankshaft Seal install
Alright so let me get you all up to speed, the belt and harmonic balancer are off, so is the old seal
i can not get the new seal to sit , i feel like its not enough room , do i remove that metal lip somehow ? seen below with the grooves
if not does this new seal from Land Rover just sit on and compress in there ? do i just whack it in?
it slides on fine , just doesn't slip in all the way
TIA
Old Jan 27, 2013 | 03:29 PM
mtrdrms's Avatar
It is a press fit and shouldn't just slide in. I just did this recently and tapped it in with a rubber mallet gently until it sat flush with the cover
Old Jan 27, 2013 | 04:30 PM
6th Gear
Actually that ring Did have to come out , it was part of my old seal lol
yes it was a press fit, went right on with a bit of force,
trucks all back together
no leaks, just came back from a car wash
Old Jan 27, 2013 | 04:42 PM
antichrist's Avatar
Did you check the crank pulley seal surface for scoring? Depending on mileage you made need to speey-sleeve it.
Old Jan 27, 2013 | 06:54 PM
6th Gear
yes i did, seemed real smooth, i only used my fingers to take the told seal out so no tool damage, needless to say the trucks together and has been running around doing errands since, no leaks so far
Old Jan 29, 2013 | 06:49 PM
cer308's Avatar
Can I ask how you diagnosed the leak to the CS seal? I have a leak slinging oil everywhere. A quart every 1800 miles or so. I get 5 or 6 1" spots on the driveway every night, mostly on the driver's side area under the steering box. I just can't seem to track down the source.
Old Jan 29, 2013 | 08:34 PM
coors's Avatar
Pressure wash until the oily surfaces are not oily. Drive rig as normal. Monitor area for leaks.
bosshogt
Jun 20, 2020 04:06 PM
humroot
Jun 21, 2012 10:51 AM
BW_Hunter
Jun 4, 2012 05:52 PM
LeakyDisco
Nov 25, 2011 09:38 PM
JRdisco1
Dec 3, 2005 10:19 AM
