please help engine immobilzer problems
Old Dec 5, 2020 | 02:41 PM
Jjackson's Avatar
8th Gear
Default please help engine immobilzer problems
Please can someone answer my treads
Old Jan 25, 2021 | 08:19 PM
rob bartleman's Avatar
hey Jjackson..... there are lots of good advisors here, but we need to know whether you've tried any of the suggestions posted for you. That helps in eliminating prospective faults. And may prompt other suggestions. Good luck.
Old Jan 25, 2021 | 08:23 PM
Jjackson's Avatar
8th Gear
Default engine immobilizer problem
Well thanks to everyone and their advice after hours of chaseing the problem it turned out to be a communication problem. A new cam wire had to be run to escape taring down the whole dashboard to find a faulty wire. Bit all symptoms pointed to tje immobilizer system.
Old Jan 25, 2021 | 08:26 PM
Jjackson's Avatar
8th Gear
Default engine immobilzer problem
After new cam wire was run landrover fired right up. I put in new spark plugs and coil packs. 100 bucks for 8 of them on parts geek, and this rover runs like a champ.
Old Jan 25, 2021 | 08:28 PM
Jjackson's Avatar
8th Gear
So from the obd plug a new cam sensor wire was run and it fired right up. After a month of hell and ideas. So the problem was between the obd plug and the dash.
dubsy46
Sep 28, 2017 04:53 PM
morrisdl
Oct 21, 2015 04:22 PM
NabisOne
Feb 16, 2013 08:19 PM
bigugly82
Dec 31, 2006 03:13 AM
lbm120
Mar 26, 2006 02:43 PM
