Pulling to the right...
Old Sep 18, 2008 | 02:28 AM
offroadlr3's Avatar
Default Pulling to the right...
Hey guys, My 05 LR3 4.4 V8 SE keeps pulling to the right.... I have gotten an alignment done (at a local shop- not the dealership) and I also noticed my drivers side front tire was bald on the inside, but fine on the outside.. I am on a budget so I bought one new tire and got it replaced... however its still pulling to the right.. I just noticed today that my power steering fluid is right below the min. line... could that be causing my steering to be thrown off? Help please! =) Thanks
Adam
Old Sep 18, 2008 | 10:46 PM
m5ccie's Avatar
7th Gear
Default RE: Pulling to the right...
There is a certain procedure to do the alignment. The LR dealer needs to "lock" the suspension using their proprietary computer. Then it can be aligned properly.
GL,
Jim
Old Sep 19, 2008 | 01:44 PM
Jantiz's Avatar
Ditto. As I understand it, unfortunately, allignment is one of the few things that actually HAVE to be done at the dealer to be done correctly. Also, if you bought another Goodyear Wrangler H/P to raplace the bad tire, my prayers are with you. That's the single worst possible tire for an LR3. Whenever you're ready for a real set of tires and feel just how comfortable and quiet the LR3 ride can be with good tires, check any of the tire related posts. Lots of good info there as well.
Old Sep 19, 2008 | 01:49 PM
offroadlr3's Avatar
Thanks, i did buy another goodyear wrangler.. =\ just to keep them consistent until i need to replace a set of new tires, instead of just a single one..
I will check out the tire related posts, and take my Rover to the dealer...
Dirtnap
May 8, 2013 02:06 PM
Doug Antsen
Mar 27, 2013 04:09 PM
30more
Feb 6, 2013 12:02 AM
DISCO1995
Oct 2, 2011 10:22 AM
llPANCHOll
Mar 1, 2009 09:34 AM
