Quick suspension question
Is it dropping all four with the fuses pulled? If it's only been left sitting normally the self-leveling will 'level' three good corners to match a leaking one, so without pulling the fuses you can't be sure what's actually leaking.
(but yeah, my bet is on valve blocks anyway)
4 days is a pretty slow leak. Not something you'll likely find with the soapy water trick. I generally leave mine sit during the week while I'm working and it usually drops some, but not all the way to the bumpstops.
endneu913
11-03-2007 03:46 PM
Question about heated windshield... dealer tech isn't answering phone, need quick answer if possible
dma3
04-04-2005 04:08 PM
