Radio/GPS issues
Old Sep 6, 2022 | 04:24 PM
shmoo235's Avatar
Default Radio/GPS issues
Hey all, 2006 LR3, does anyone know if the GPS drives the radio or if the radio drives the GPS. Both take time to turn on "some" times however the radio is not responding to any buttons being pushed. Stuck on one station and nothing changes although it has changed on its own to a different station. Did the whole battery disconnect thing and any other trick I could think of but still not responding. I don't use GPS but it seems to work whenever it's "on". If Radio is the lead power may want to get another radio whether GPS works or not I don't really care. Just want music.....Any advice much appreciated...........
Old Sep 6, 2022 | 05:00 PM
DakotaTravler's Avatar
I have no clue what you are asking. The GPS works with the navigation system, it has nothing to do with the radio.
Old Sep 6, 2022 | 05:51 PM
shmoo235's Avatar
OK thx but they both go out and come on at the same time so something is powering the 2 at the same time
Old Sep 7, 2022 | 04:40 PM
Ram2022's Avatar
Default I have a 2009 rr and nothing works it stays on this screen don't know what to do ,
Old Sep 7, 2022 | 06:25 PM
A 2009 RR is not an LR3.........
Old Sep 7, 2022 | 10:09 PM
houm_wa's Avatar
....sure is a sexy interior, though.
Old Sep 10, 2022 | 08:03 PM
Rufflyer's Avatar
Default Here is what I know about power to the radio
The wiring diagram pages 146 thru 155 show the high line radio option.
You can follow along if you want, but it seems that it is NON switched power and switched power.
BUT if you are interested in where the power does go (so you can check each piece of equipment)
Here is how it flows:
Positive terminal
OUT - C0192-1 (Connector 0192 pin 1) red wire
Battery Junction box
IN - C0632-1 red wire
Link 18E (50 amp)
OUT- C0570-186 brown and grey wire
Central Junction box
IN- C0583-22 Brown and grey wire
inside the CFB it splits to
FUSE 42P -OUT- C0582-22 red wire to amplifier-power-ICE
FUSE 52P -OUT- C0582-41 red wire out to telephone control unit
FUSE 53P- OUT- C0582-38 purple/blue wire to junction SJ131 then audio control unit
FUSE 56P-OUT- C0582-13 blue wire to SJ998 then other things
Relay R249- OUT to FUZE 56P-C0582-13 blue wire to Junction SJ998 and to
FUSE 62P-OUT- C0582-8 red wire to C2443-12/C24444-12 then a brown wire to ???
Relay Solenoid - OUT C0582-34 red and purple wire to Audio head unit C0582-34 ( for control)
Junction SJ998 (all blue wires)
1 lead goes to touchscreen C2819-1
1 lead goes to module-multi-media C2144-18
1 lead goes to TV tuner module C2117-1
1 lead goes to telephone control module C2777-16
1 lead goes to DAB antenna amplifier C2671-1
Junction SJ131 (all purple wires)
1 lead goes to the audio head C1354-11
1 lead goes to Module-Multi-Media C2114-17
1 lead goes to Touch Screen C2819-11
It looks like power goes into the CJB, out to the audio head unit (always on) then the control head controls relay R249 that adds power to SJ 998 which then powers all the other things listed on JS998.
Power is also always on to the Amplifier and telephone units
Hope this helps more than it confuses
Jeff
General disclaimer: I may be wrong
Old Apr 19, 2023 | 11:31 PM
Dorel's Avatar
Thank you!
elboy0712
Oct 22, 2017 09:33 PM
dcaven
Audio/Visual Electronics
Sep 3, 2017 04:23 PM
codemunky
Jun 25, 2011 04:56 PM
puchita
Aug 17, 2008 08:33 AM
dbwarren
Dec 14, 2006 12:08 PM
