Range Rover Sport BCM no crank.
Old Dec 4, 2019 | 11:12 AM
Captainbeaky's Avatar
Default Range Rover Sport BCM no crank.
OK, weird one.
L319 (Range Rover Sport) TDV6 auto in for BCM change.
Old BCM is displaying a problem with the rear electric windows not working, and flagging an internal error.
Customer wants it fixed, as working windows is part of safety inspection here.
Bought a used BCM (Exactly the same version and part number), and installed it - flashed correct SW and synched config file no problem.
Rear windows now work, but no crank!
No fault codes at all - and no immobiliser messages.
This has got me a bit stumped, as I didn't think that the starter motor trigger went through the BCM (according to RAVE diagram, it doesn't on the TDV6 auto!)
I turn the key, I hear a relay click down there - which I think is for load relief - but no bloody crank!!!
Nothing else untoward...
Any ideas?
Thanks,
Mike.
Old Dec 4, 2019 | 06:04 PM
DakotaTravler's Avatar
Did you swap the original BCM back in?
Old Dec 4, 2019 | 07:58 PM
loanrangie's Avatar
Try a soft reset then hard rest.
Old Dec 5, 2019 | 04:44 AM
Yes, tried original BCM back in - and it starts.
Tried soft and hard reset - no go.
Does the start relay earth go through the BCM on an auto?
Old Dec 5, 2019 | 11:10 AM
LR Techniker's Avatar
BCM is the main component for Immobilizer. It stores the key data. I don't know what tool you used to programmed the spare module, but it should have prompted you to learn the keys.
Workshop info says you cannot swap used BCMs, but I would learn the keys and see what it does.
Tgottwald
Jan 7, 2019 07:41 AM
Squeaks
Feb 14, 2016 02:19 PM
Moses7
Apr 17, 2013 07:00 AM
TAHOEman
Dec 7, 2010 09:50 AM
newser
Sep 2, 2007 02:32 PM
