Ready to Tow?
Old Jul 28, 2022 | 11:13 AM
douglastic's Avatar
Should have zero effect
You just need a ball mount with less rise, so your trailer is still level
Old Jul 28, 2022 | 12:22 PM
tracyc's Avatar
There are too many reports of the quick release ones failing under load for me to ever trust them. I installed a Curt frame mount hitch.
Originally Posted by ManUtdWY
Anyone out there using the quick release with a 2.5" rod lift? Curious if the lift changes the geometry enough that the quick release wouldn't handle the same size tongue weight and GVWR.
Old Jul 28, 2022 | 12:28 PM
ManUtdWY's Avatar
guess I better read up on failures then. Having the maximum departure angle is important to me when not towing, which made the detachable option preferred over the frame mount, but safety and prevention trump above all. I just wish you could pull out the useless recovery point and put the receiver in it's place! Thanks.
Old Jul 28, 2022 | 01:09 PM
tracyc's Avatar
Yeah, it's a bit of a controversy. Plenty of people on both sides for the detachable ones. But, there are zero reports that I'm aware of for a name brand frame mount hitch failing in the LR3 - which to me, says a lot.
They don't compromise departure angle very much btw.
Old Jul 28, 2022 | 02:26 PM
douglastic's Avatar
Guess you haven't seen this then:
https://expeditionportal.com/forum/t...6/post-3025892
BTW - the LR hitch failures were all 1st gen (poor longer design) weren't they - not the current 3rd gen stout design?
Old Jul 28, 2022 | 02:40 PM
tracyc's Avatar
That's not what I mean by a frame mount hitch. I'm talking about the full size ones that bolt to the frame at multiple points under the car around the spare tire area.
Old Jul 28, 2022 | 04:42 PM
douglastic's Avatar
Curious, why do you think it is useless?
I think it's probably one of the most stout factory recovery points put on a production 4x4.
Best place to put a shackle when off-roading. Way better than a hitch shackle.
Old Jul 28, 2022 | 05:14 PM
ManUtdWY's Avatar
I mean, as far as recovery points go, you’re right, very stout, but my opinion is that it is useless because that spot is the best location for a receiver and there are other locations that allow for a stout recovery point. Plus, while a hitch shackle is less preferable, it is functional and at least gives me choice.
S4poor
Feb 10, 2008 10:15 AM
shendren
Defender
Jan 22, 2008 01:22 PM
apcollin
Oct 7, 2006 12:05 PM
Disco.Jay
Mar 14, 2006 12:36 AM
rlpayne
Audio/Visual Electronics
Nov 16, 2005 04:22 AM
