Rear AC elimination.
God morning.
As I was poking around underneath the car I discovered, that my LR3 has a multiple leaks on various AC pipe connections. Don't want to replace as this will be costly and fiddly to do since all the rear AC pipes are pre bent and NOT easy to get to. Does anybody eliminated rear AC altogether and installed a pipe in engine bay without rear aC connections that is usually fitted in SE models ? I could not care less about having a rear air conditioning as I don't drive anybody around anymore.
I had the same issue. Under the driver side rocker panel, we cut the a/c lines and soldered them shut. Refilled the refrigerant and it's been working well for the last 3 months. In the back seat, the 2 vents from the center console are cold but the overhead is just ambient air. Heater is unaffected. I'm happy with the results.
