Rear brake rotor and pad grooves
Old Jun 23, 2020 | 08:11 PM
krazi3azn's Avatar
8th Gear
Default Rear brake rotor and pad grooves
Just bought a 2008 LR3 and noticed the rear driver rotors has very large grooves. The passenger side is not as bad but I can feel it with my finger tips. What would cause this? The pads still have a lot of life left. Should I change them out? I bought the rotors and pads since they were cheap.
Old Jun 23, 2020 | 10:24 PM
DakotaTravler's Avatar
Not exceptional. Generally cheaper pads/rotors do this it seems. But even the type of pad used can cause this more or less than others. Cheap semi-metallics seem to have larger metal bits in the pads. A sticking caliper can sometimes cause this too by letting the pad gently drag along the rotor. After driving for a bit you can touch the hub part of the rotor and see if they match side to side temperature wise. If one is a lot hotter, you have a dragging issue.
Old Jun 24, 2020 | 01:13 AM
Globetrotter448's Avatar
Grit thrown up from the road can do this and as been said some metallic bits in the pad. Some places will skim them for you.
Old Jun 24, 2020 | 09:27 AM
krazi3azn's Avatar
8th Gear
Caliper is not sticking at all. Safe to run? Or would you recommend replacing?
Old Jun 24, 2020 | 06:15 PM
Check whether there is a lip at the outer edge of the disk. If so replace, if not then good for more miles
Old Jun 24, 2020 | 08:16 PM
I dont see a reason to replace. Maybe to keep an eye on, but they are not really bad. I mean it would not bother me at all.
Old Jun 24, 2020 | 08:27 PM
krazi3azn's Avatar
8th Gear
there was a little lip so I decided to swap them. I’m pretty sure previous owner swapped pads but not rotors. For $130 CDN for both rotors and pads and sensor it wasn’t too bad
ljdiscovery
Dec 28, 2018 11:28 AM
Jnx78
Jul 20, 2016 09:56 PM
kenk
Aug 6, 2013 02:48 PM
AgentX
May 4, 2009 11:40 PM
