Rear Control Arm or Bushings?
Old Nov 15, 2017 | 03:46 PM
AdrenalinPlease's Avatar
Default Rear Control Arm or Bushings?
Right rear upper control arm has play on one of the bushings, do I replace the bushings? Complete arm? Around $100 for a complete arm...
Old Nov 15, 2017 | 04:57 PM
I have the same issue on mine going to do the arm and the outer bushing. Seems like a safer bet.
Old Nov 15, 2017 | 11:14 PM
EastCoast's Avatar
I found it easier and cheaper to buy the arms than have the bushings pressed.
Old Nov 16, 2017 | 03:12 PM
I think that's what im doing.
Old Nov 18, 2017 | 07:54 PM
TOM R's Avatar
They will keep breaking , if you plwn t o keep it a while invest in urethane bushings like we did L8 sells em
Old Nov 20, 2017 | 02:36 PM
You mean the poly bushings?
Old Nov 20, 2017 | 03:33 PM
EastCoast's Avatar
Not sure the bushings "break" per se but rather wear out. Mine lasted 10 years and if I get close to that with the replacements, I'd be happy. From what I've read, the poly's are a bit harsher and were implicated in at least one control arm snapping.
Old Nov 20, 2017 | 10:32 PM
TOM R's Avatar
We run poly with no issues so far been 2 years?
jft1428
Mar 22, 2018 10:25 AM
kenk
Nov 4, 2013 02:24 PM
Disco Mike
May 4, 2011 07:08 PM
asv4k8
Mar 7, 2011 07:29 PM
kenk
Jul 6, 2010 08:34 AM
