Rear door card
Old Aug 12, 2019 | 05:45 PM
houm_wa's Avatar
Default Rear door card
...anyone changed the inside door panel? Easy DIY? Take long? Special tools needed? Thanks in advance!
Old Aug 13, 2019 | 04:27 AM
Identamerican's Avatar
Buy some panel clips because you'll probably break most of them holding the panel on. There are from what I remember 2 screws in the door handle, 2 in the "grip handle" or whatever you want to call it, and 2 in the bottom of the panel, all philips tip. Then there are 6 clips on either side that pop off and 4 in the top and bottom, don't quote me on the exact number. The only real pain is getting the lock assembly off, and while it's off you might as well make the adjustments required to prevent the actuator from failing, even though you don't necessarily need to remove the lock assembly to replace the panel. I suppose you'll also want to switch out the speaker, I forget if that's screws or clips but you just disconnect from the wire harness and put the speaker in the new panel, nothing tricky. Remember to chalk the window if you're doing the actuator as well!
Should take about an hour all together.
emncfi
Sep 23, 2024 09:24 AM
chicane
May 15, 2014 09:42 AM
cationmoted
Dec 4, 2010 08:55 PM
amylynn
Dec 18, 2006 06:34 PM
Benhamtroll
Feb 22, 2006 02:52 AM
