Rear heat LR3
Old Jan 12, 2018 | 07:36 PM
deemanLR3's Avatar
Default Rear heat LR3
LR3, SE, 116K, 2005
The Heater core has recently been replaced, due to no heat on the driver side and the left front windscreen. So the front heat is now working great - it's the back that is the problem. When the back is on "Auto' (top light on ) the hot airs comes through the console just fine. It's when you use the climate control in the back (bottom light on) the issue arises. The fan speed seems to work fine - meaning there is a change in speed as you turn the dial. However, there doesn't seem to be any heat - just lukewar aim. Any ideas?
Old Jan 13, 2018 | 03:34 PM
deemanLR3's Avatar
Just an update, All the vents in the rear seem to work fine. If I turn rear controls to blue the air from the vents is very cool ( air con cold ). However, when I turn the controls to red, the temp increases but it's not even lukewarm. Does anyone have some suggestions on how to troubleshoot this? The front heaters work normally
Old Jan 13, 2018 | 07:46 PM
I wonder if there is restricted flow of coolant to the rear system
Old Jan 14, 2018 | 08:21 AM
deemanLR3's Avatar
I know nothing about these heaters. I took a look at the "412-03D_Auxiliary_Climate_Control_Description_and_Oper ation.pdf" and there seems to be a "Heater core inlet pipe". Would I first need to check whether there is heat coming in from the main heater core?
Old Jan 16, 2018 | 08:28 AM
deemanLR3's Avatar
Here is some other information to consider. I spoke with my local specialist and because I've already had one heater core problem - the front. They believe that more than likely the rear heater core is shot as well. I'm will be getting it diagnosed on Monday and will provide an update
Old Jan 21, 2018 | 07:18 PM
samnt650's Avatar
Good luck with the rear heater core. Its behind the left rear tire. Real PITA to access and service.
Old Jan 24, 2018 | 10:11 PM
deemanLR3's Avatar
@samnt650 do you know of any manuals on how to tackle this job?
Old Feb 9, 2018 | 07:33 AM
deemanLR3's Avatar
to close this out. The shop said that the rear heater core is blocked and it's a 4hr job to replace - I'm not going to move forward with the repair
Old Feb 9, 2018 | 11:58 AM
Heat it highly over-rated anyways
It is odd that both the heater cores plugged up though.
Old Feb 9, 2018 | 03:07 PM
abran's Avatar
Yep, book time is 3.6 hours.
