Rear right air suspension not reflating
Old Apr 16, 2021 | 07:36 AM
dimlylit33's Avatar
6th Gear
Default Rear right air suspension not reflating
I brought my 2005 LR3 (90k miles) to an independent mechanic for replacement of both rear upper control arms (which were quite rusty). The process required some grinding and cutting, resulting in an inadvertent nick of an air line on the rear LEFT side of the truck. A repair kit was purchased and that air line was fixed. After the work was complete, the air suspension reflated at all corners except the rear RIGHT one. I had experienced no issues with suspension function before this. The mechanic is working through some troubleshooting but I was wondering if the LRForums brain trust had any relevant experience to impart. Thanks in advance for your shared wisdom.
Old Apr 16, 2021 | 10:05 PM
DakotaTravler's Avatar
Well you either have a leak OR the rear valve block was messed with and the lines hooked up wrong. Thats about it, pretty simple system.
Old Apr 25, 2021 | 10:45 AM
dimlylit33's Avatar
6th Gear
You were right. He found a leak in the air line on the right side (somewhat hidden up in the body). Repair kit fixed it. Back in action. Thanks for the wisdom.
Old Apr 25, 2021 | 10:49 AM
More wisdom - avoid that mechanic. The air lines are not in a position they can be easily damaged when doing the back end. The gavel block is close, but its very obvious it can be simply lifted up and moved with no tools.
Bishen67
May 8, 2017 05:22 PM
lrnewb
Mar 6, 2015 10:21 AM
Gerard
Feb 5, 2012 02:21 PM
Firsty
Feb 23, 2008 06:38 PM
Firsty
Feb 22, 2008 08:00 AM
