Rear Sunroof Drain Locations - LR3
Plenty of info on the fronts. Mine are toast by the way, dumping right into the cabin. I am not sure if the rears are as bad, but I would like to look at them. With that said, I am having a hard time locating a thread discussing the rears in any detail. I would love to know where they terminate exactly and how to access them. Just the ends, I dont with to take the headliner off. And do they use the same end elbows as the fronts? I ordered two elbows for the fronts already, they are from another vehicle but look almost identical. I will see if they work, if they do its a MUCH cheaper solution to buying a whole hose.
For now I put electrical tape around the sunroof to seal it up while I wait for parts. Did the same with the windshield too until the cowl arrives.
ljdiscovery - I dont have a link posted for those above because I am not certain they will work. They arrive tomorrow and I will try then out. If they work, they cost is only about $10 USD each. And I will post the part number/link. Also these have the similar tampered end I will probably cut then off before install to reduce clogging.
