Rear Tail/Brake Light
Old Dec 3, 2013 | 06:28 AM
keithlarue's Avatar
6th Gear
Default Rear Tail/Brake Light
*Revised*
I generally back in my Garage, when leaving out I can see the rear of my vehicle reflecting off of the glass sliding door. I noticed that while depressing the brake slightly the drivers side brake light wasn't illuminating, the 3rd brakelight & right side were so, I stopped placed it in park, and got out to examine the drivers side bulbs. It just wasnt registering how the top bulb was not "blown" and illuminating with the lights on but not glowing brighter when the brake is pressed.
Could it be a relay thats bad for that top bulb to glow brighter when applying the brake ?
Old Dec 3, 2013 | 02:04 PM
houm_wa's Avatar
I'm not sure I understand....
Gosh, I guess I don't remember for sure but I'm 90% certain that the parking lights and brake lights operate with separate (but the same part no) bulbs.
Old Dec 4, 2013 | 06:49 PM
houm_wa's Avatar
I'd start by removing the assembly (it's not difficult) and examining both bulbs. Likely one is just burned out.
Old Dec 4, 2013 | 08:40 PM
roverguy7's Avatar
It's a 1157, dual element bulb, high wattage for the brake light, lower for the tail light. If it is just it not illuminating when pressing the brake, probably just the bulb, if it is turning off the bulb completely when lights are on and then brake is pressed, take a good look at the bulb socket, had several issues with the ground contact.
Old Dec 5, 2013 | 06:43 AM
keithlarue's Avatar
6th Gear
Thanks Guys, will tackle this weekend
rambo
Oct 17, 2013 10:13 PM
pottzie
Jul 12, 2012 06:32 PM
Kalel
Mar 29, 2012 08:31 PM
primey
Oct 5, 2011 10:06 PM
Classic89
Nov 1, 2010 08:40 PM
