Recovery shackle.
Old Feb 24, 2016 | 12:11 PM
DavC's Avatar
try winchline.com for shackles.
I have not had any issues using 3/4", have not tried 7/8" yet...
Ditto on getting some soft shackles. Have been meaning to get some.
Old Feb 24, 2016 | 01:34 PM
DustyLBottoms's Avatar
What are the benefits of soft shackles?
Old Feb 24, 2016 | 01:58 PM
DavC's Avatar
If they fail they don't become projectiles. Maybe to daisy-chain recovery straps like the aussies do on big beaches where they need to get to firmer ground to un-bog someone. I have seen them just tie the straps together though. In theory a lighter, less dangerous shackle. Prone to abrasion though is the downside I imagine.
Old Feb 24, 2016 | 04:21 PM
binvanna's Avatar
Main advantage is it's not a projectile when the line breaks. Soft shackle is also easier to stow since it doesn't pound objects around it, rattle or weigh much. For sure, I would rather have a loose soft shackle in my car than a steel one.
Old Feb 24, 2016 | 07:16 PM
thorgal's Avatar
Originally Posted by Zelatore
Interesting. I put a Bubba Rope on a 3/4" shackle this weekend with issues....?
I run 3/4" steel and a couple of Lucky8's soft shackles for when a standard simply won't work. For anybody who questions the strength of a soft shackle, just this weekend we tore the steel recovery eye out of an ARB bumper with one and didn't cut a single strand on the soft shackle. Those things are tough.
I don't just own just a ordinary bubba rope , i have Big Bubba Rope , which is a massive kinetic line , that just won't fit into 3/4 shackle , even 7/8 has to be forced in , so to speak..
Old Feb 24, 2016 | 07:34 PM
As others have pointed out they don't kill you if they let go.
The real benefit in my eye is the way they are set up to work. By being flexible just like winch line you can get around non-traditional recovery points when needed. I have seen them used on frame out riggers, wheel spokes, hitch support brackets you name it.
When these first hit the scene everyone assumed they would fail and they were useless/stupid. I have seen them used hundreds of times over the last few years in about every situation I can imagine. I've seen them used to recover completely buried Rovers, rolled rovers and a wrist bracelet sized one to pull a Toyota Tacoma out. I have yet to see one fail and I was one of the nay sayers that has been converted.
My recovery gear bag only has soft shackles, I can't even understand using the crappy metal ones anymore.
Old Feb 25, 2016 | 12:10 AM
Zelatore's Avatar
This. They are really versatile and amazingly strong. While I haven't ditched my steel shackles yet, I may do so just for the weight/space savings. I think I currently have 2 soft and 4 3/4" steel in my bag.
Old Feb 25, 2016 | 12:59 AM
jimvw57's Avatar
I got the 3/4 ones (13048B) They fit perfectly on the hitch tow point on the rear of my truck. Haven't gotten stuck yet so I have not used it but if and when I get stuck, I do have an option. Not too sure about using the hitch as a tow point but it was convenient and it met the requirements for the off road event I attended. Also have a 35 ft strap rated at 12,000 lbs all in a bag under the seat.
Rover_Hokie
Feb 4, 2014 02:38 PM
Fivespddisco
Sights N Sounds
20
Jan 19, 2012 06:34 AM
hilltoppersx
ROAMING WITH FRIENDS
Apr 18, 2011 11:46 AM
mikemeyer0
Off Topic
May 26, 2005 06:59 PM
inclinedvehicles
Member Group And Special Buys
Feb 7, 2005 11:29 PM
