removal replacement of air suspension lines
Old Oct 17, 2014 | 12:19 AM
ljdiscovery's Avatar
Default removal replacement of air suspension lines
Hey All, I am in the process of removing and replacing the air suspension lines. I went to remover the nuts that hold the lines on the top of the air shocks and bam, how the heck do you get these off? Do you need to remove the shock to remove and replace the air lines? What is the trick? thanks Phil
Old Oct 17, 2014 | 11:39 AM
unseenone's Avatar
Wow, these ads are getting ridiculous..
You'll need to depressurize the system first. If you need manuals drop me a pm with email add.
Old Oct 17, 2014 | 01:11 PM
One of the lines was cut in an accident. Truck has been sitting and it is now on the chocks. Looks like you need to remove the air spring/shocks to get to the air line nut, gotta love Land Rover........nothing is simple or easy on these things. Well, except spending cash.......
Old Oct 18, 2014 | 11:33 PM
bbyer's Avatar
Default dealers jack/lift on the frame
I have noticed that the LR dealers and tyre shops that truly understand the 3 and 4, well all air suspension vehicles, lift/jack on the frame such that all the wheels and suspension components droop/hang down.
That seems to be the safe way to handle the vehicles as unplanned release of the suspension air while often causing some unanticipated wheel and suspension movement, at least the body stays put.
TRIARII
Feb 26, 2015 11:13 AM
ljdiscovery
May 28, 2014 09:46 PM
hsuflyguy
Aug 24, 2013 03:19 PM
Triple
Jan 24, 2013 10:01 PM
rich
Mar 7, 2010 02:52 PM
