Replace Voss valve without removing whole front air strut?
Old Jan 2, 2025 | 06:04 PM
Eyelid_movies's Avatar
Default Replace Voss valve without removing whole front air strut?
Hi Everyone. Many thanks to all of you who have posted info on this site. A soapy water test on the passenger side front air strut of my 06 LR3 is showing bubbles at the Voss valve which connects the airline to the top of the strut. I was wondering if anyone had experience of replacing the valve (the brass fitting and pinch ring) without removing the entire strut first? Can it be done or is there not enough space to do the required manipulations? Any comments greatly appreciated.
Old Jan 2, 2025 | 07:07 PM
loanrangie's Avatar
Its not a valve just a fitting, space is tight but you can undo the fitting easy enough so replacing it wont be any harder.
Old Jan 3, 2025 | 05:20 PM
DakotaTravler's Avatar
You do not have to remove the strut, per say, but it will be easier if you deflate the bag with the truck jacked up and remove the top three nuts at least. Will give you a lot more room to work with. Odd spot for a leak though.
Old Jan 6, 2025 | 12:14 PM
douglastic's Avatar
I just went thru this
I could not for the life of me tighten the fitting without lowering the strut
I can't imagine successful replacement without lowering
Chris Gatan
Feb 8, 2021 06:21 PM
Ben Matheson
May 15, 2019 04:41 PM
josher-mi
Jan 19, 2019 01:54 PM
colin2496
Oct 17, 2011 09:58 AM
