Replacing rear strut
Old Mar 21, 2015 | 05:56 PM
DavC's Avatar
Default Replacing rear strut
Trying to fix an ongoing leak either at the passenger side rear strut or at the rear valve block.
I know that the valve block for the rear axle is on the drivers side somewhere behind the wheel but haven't found any diagrams that point to it exactly. How do I get to it? I've seen people depressurize the front by slowly manually releasing pressure through the fittings, is this damaging at all?
Lastly, once I swap out the offending strut, do I need to reallign the vehicle? If its not for steering like the front, would it be because of camber?
Thanks
Old Mar 22, 2015 | 11:04 PM
houm_wa's Avatar
I don't believe an alignment is necessary after, but a calibration of the sensors is.
Old Mar 23, 2015 | 08:28 AM
cmb6s's Avatar
You can take a look at my gallery here to get a better idea of where the rear valve block is. Keep in mind that there are three valve blocks total, the front, rear, and reservoir.
DISCO3.CO.UK Photo Gallery - EAS
As far as a calibration, you should not need one unless you replace a height sensor or sensor rod. The strut itself has no effect on how the suspension height is measured unless one of the fixed measurement points is on the strut itself (which I don't believe it is from memory). Shouldn't need an alignment either unless you have to remove a control arm for some reason...
Old Mar 23, 2015 | 11:22 AM
houm_wa's Avatar
Yeah that may be correct. When I had my air shock replaced I also needed a sensor. I just remember needing a calibration and didn't distinguish why. FOR SURE if you replace a sensor you have to calibrate.
Old Mar 23, 2015 | 12:41 PM
DavC's Avatar
Oh man, am I going to have to worry about replacing the height sensor if I swap a strut out?
Old Mar 23, 2015 | 01:29 PM
cmb6s's Avatar
No. Completely separate things. I'm guessing houm did it for preventative measures or because something got damaged.
Old Mar 23, 2015 | 02:46 PM
houm_wa's Avatar
I did it because my 32" MT/Rs tore up some $hit....
Old Mar 23, 2015 | 09:44 PM
DavC's Avatar
Okay I'm going to go ahead and swap the strut out this week, is it going to be an issue if I'm only changing one side out at a time?
Old Mar 24, 2015 | 11:18 AM
houm_wa's Avatar
I don't think there is official guidance on that. Most suggest that you replace them in pairs, but I'm not sure that there is any real reason for that besides seat-of-the-pants feel. I replaced one corner and put the other on my "watch list" looking for contact between the upper control arm and strut at full droop. So far so good. That doesn't mean that I've taken a performance hit in terms of on-road ride; I just don't remember since I've had the LR3 for ten years.
Forester
Dec 1, 2022 02:19 PM
spazzz2002
Freelander
Jul 27, 2013 09:31 PM
payback
Feb 29, 2012 09:15 AM
RoverSC
May 13, 2008 01:53 PM
tjfls4
Sep 19, 2007 03:58 PM
