Replacing tensioner pulleys?
Old 11-21-2019, 09:56 PM
Oceanguy33's Avatar
Thanks. Now I am more confused. I only meant to buy the pulleys for the tensions - main and accessory. Have I purchased the wrong one for one of them?
Happy Thanksgiving BTW - up here in Canada we had ours last month...
Old 11-21-2019, 09:57 PM
DakotaTravler's Avatar
Well you should replace all three anyway. The idler certainly goes bad and it’s easy to replace. I don’t have all the specs on hand right now and I am in bed. But I think I had a post on this topic before. I may have listed the parts, etc.
Old 11-21-2019, 10:00 PM
Oceanguy33's Avatar
Thanks.
You know you're supposed to quiet the mind before bed...Not sure this helps
Old 11-22-2019, 04:41 PM
Philip Chan's Avatar
My tensioner from rock auto shows spec as 25mm width
The spec on the tensioner unit (full unit) show the pulley with a spec of 30.5
Should I worry? 5mm isn't insignificant...
Old 11-22-2019, 05:37 PM
Actually 5mm is significant. Again there are two tensioners, they are not the same or interchangeable. Also both belts are not the same width. I *think* that tensioner would be for the main drive belt, the forward belt. You would have to cross reference the part numbers.
Old 11-22-2019, 05:58 PM
Yes - I know. Sorry I used a double negative . It IS significant (conversely it isn't insignificant).
The smaller width one could be for the accessory (ie. the one closest to the engine) as that belt is narrower.
The idler pulley I have is also narrow too I believe. the Main belt - is thicker (the one that loops the fan clutch and crank).
Old 11-22-2019, 06:39 PM
And I read too fast. Oops.
Old 11-22-2019, 06:45 PM
I can't seem to find the part numbers for this - either on Rock Auto or other. The LR part for the arm AND pulley is readily available. I now see that the main belt tensioner seems to run 37mm - which none of the rock auto pulleys seem to work out...
will keep searching....
Old 11-22-2019, 08:53 PM
Diagrams and part numbers:
Diagram and part numbers:
Quick Reply: Replacing tensioner pulleys?
