Ride Height Adjustment Frequency
Not necessarily, though the sensors are continuously monitoring heights. I notice that sort of thing at stops on weird angles mostly. If you have a Nav system, you can put it on the 4x4 info screen and see if one wheel is going out of whack witch might indicate a bad height sensor on that wheel. You might also have a leak somewhere, you can go after it with a spray bottle of soapy water and see if you have a leak..
MaxColee
10-06-2008 10:21 PM
Speed racer
09-09-2008 03:05 PM
