Ride Height Adjustment Frequency
Old May 20, 2015 | 11:36 AM
Volkov's Avatar
Default Ride Height Adjustment Frequency
I have a quick question regarding how often the computer should make ride height adjustments. My LR3 seems to make a change every 5-10 minutes, at least those are the changes large enough for me to notice and for the compressor to kick on. Is this normal?
Old May 21, 2015 | 07:25 AM
unseenone's Avatar
Not necessarily, though the sensors are continuously monitoring heights. I notice that sort of thing at stops on weird angles mostly. If you have a Nav system, you can put it on the 4x4 info screen and see if one wheel is going out of whack witch might indicate a bad height sensor on that wheel. You might also have a leak somewhere, you can go after it with a spray bottle of soapy water and see if you have a leak..
Delray
Mar 2, 2014 07:34 PM
BlackAvon
Freelander
Oct 20, 2009 05:28 AM
Young
Oct 7, 2008 07:43 AM
MaxColee
Oct 6, 2008 10:21 PM
Speed racer
Sep 9, 2008 03:05 PM
