Right Rear Wheel Noise
I have been driving recently and noticed around 35 mph to 50 mph I started hearing wheel noise from the right rear.
I jacked the rear of the truck.
RR: no movement when I shake the tire at 3-9 o’clock positions. Slight play when I shake top to bottom (12-6 o’clock). Also slight play at 11-5 and 1-7 positions.
LR: same thing
i try to shift the weight of the truck by going around the turn to see if the noise goes away but hard to tell.
I also ran my hand on the thread and it was relatively smooth may be a slight ridge (tire cupping) but nothing too noticeable.
question: should there be any play top to bottom or at 45 degrees (diagnol) but not 3-9 o’clock (side to side)?
I understand the wheel bearing is an issue with these trucks.
LR: same thing
There should be no play. Wheel bearing are issues with all vehicles. The fronts on these seem to last around 100k-120k or about. Rears 175k is about when they start to be questionable. Make sure you check all wheel bearings. Took a truck out on a test run to ID a noise. One front bearing was already done and the noise really sounded like passenger rear according to the owner and even when I drove it, thought so. But we checked them all and found out it was front passenger. Sound can transfer all over the place.
Thanks for the advice. I am assuming you meant “bearings” not “bargains” lol
When I get the chance, I am going to jack up the front and check as well. Will post anything I do as well.
