Rims -9 inch
Old Mar 25, 2022 | 08:28 AM
Oceanguy33's Avatar
Default Rims -9 inch
Just wondering if anyone could comment...
I am putting 265/65/18 on with a 2 inch lift. My previous LR3 had the exact same set up, except with stock 10 spoke 18s (which I think are 8inch wide?) The after market rims I got are 9 inch. Do you think this is an issue or will I req. spacers?
Old Mar 25, 2022 | 11:12 AM
DakotaTravler's Avatar
Kinda need to know off-set of the new rims.
Old Mar 25, 2022 | 11:45 AM
Oceanguy33's Avatar
Rims are ET35
Old Mar 25, 2022 | 12:06 PM
I doubt you need a spacer, your new rim size will actually push the wheel outwards a bit according to this chart. And since 265/65/18 is the max zero mod tire size, you should be fine there though. Obviously do a test for of one before committing to all four.
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
landroverdude
Jun 12, 2020 04:58 PM
disco ben
Apr 5, 2009 01:37 PM
Disbet
Jul 14, 2008 06:41 PM
Harvard
Apr 30, 2008 04:58 PM
brendan
Jun 29, 2006 10:36 AM
