roof rails
Old Oct 16, 2014 | 09:12 AM
TOM R's Avatar
Default roof rails
ok so we used the key and unlocked the rails. slid them to the middle where it looks like you should just remove them and they will not come off, am I missing something?
Old Oct 16, 2014 | 09:48 AM
jafir's Avatar
Did you loosen the allen bolts? Also, there are a few spots they can come out, if I remember correctly, but they are a pretty tight fit. The bars have to be completely perpendicular to the rails or they will bind trying to remove them. They CERTAINLY aren't as quick on and off as the D1 or D2 bars.
Old Oct 16, 2014 | 10:35 AM
TOM R's Avatar
allen bolts? I assumed you just unlocked them and slid to the large open spot in the track and lift them out, guess I will look for the allen bolts
Old Oct 16, 2014 | 10:38 AM
jafir's Avatar
It just loosens up the feet so that the can move in and out a little on the bars.
Here is the destructions: 60940.pdf
Old Oct 16, 2014 | 01:19 PM
TOM R's Avatar
I figured it thanks, just unlock the ends and slide off that top little plastic plate, the Allen screw is there, loosen just 1 per bar, slide them to the middle and lift off
Womble
Jul 30, 2015 01:58 AM
austinlandroverbill
Jul 24, 2015 12:00 PM
dbeard
Apr 28, 2015 08:40 PM
clmolnar
LR2
47
Jun 16, 2013 02:27 PM
borat
Jun 1, 2007 07:07 PM
