SD Roof Rack Fitment With Extended Roof Rails
Old Apr 28, 2015 | 12:49 PM
dbeard's Avatar
Default SD Roof Rack Fitment With Extended Roof Rails
Hey Gang,
Thinking about installing an SD roof rack, and I was wondering If I need to remove the OEM extended roof rails in order to fit an SD rack. I have spotted a used SD rack close by, and may consider purchasing. Are there two different types of highlander roof racks? I want to make sure I'm purchasing a rack that fits, becuase I'll be installing it at the person's house I'm buying it from in order to transport home.
Old Apr 28, 2015 | 01:06 PM
Alex_M's Avatar
It should fit considering it fits over the front rails, but I'm someone will come by and either confirm or correct this.
Old Apr 28, 2015 | 01:36 PM
abran's Avatar
It will fit
Old Apr 28, 2015 | 08:07 PM
coors's Avatar
If your rear sunroof sticks up higher than your extended rails, you'll be fine.
I can open my rear sunroof no problem with the SD rack.
Old Apr 28, 2015 | 08:40 PM
antichrist's Avatar
They made two versions, one (with longer legs) for with the roof rails, one for without. Odds are really good it's the one for Discos with roof rails, but worst case you can remove your roof rails.
Womble
Jul 30, 2015 01:58 AM
austinlandroverbill
Jul 24, 2015 12:00 PM
DiscoBlanco
Sep 24, 2011 02:08 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
