Rubbing for 265/70R18 LR3
All-
I am a LR3/Land Rover noob and wanted to ask a question-
How concerned should I be with minor tire rubbing with 265/70R18 tires?
I installed the Johnson Rod 2.5" lift on my 2006 LR3 and it seems there is a bit of rubbing when I turn the wheel to its maximum extent and when I take hard turns (I assume leaning of vehicle ie sharp exit ramps)
Clearly, despite my research, I could not help myself with the 32.6" tires- Should have gotten the 32.00"
Thanks for your responses-
James
James
jbullock78 (04-10-2018)
What years of the LR3 had the frame horn? My 2005 doesn't have it.
I am running the same size tire. Haven't experienced any rubbing yet, but I have not flexed my suspension (off-road) yet.
Qualifier: I am running 32.6" tires, but they are 275/65R18s. Coopers run a little larger. I previously ran Goodyears in that size and had no issues.
