Shifting Blues
Old Aug 8, 2023 | 03:29 PM
crum67's Avatar
Default Shifting Blues
My 2009 LR3 HSE does not want to shift gears, I'm having to use the E shift to get anywhere. Also, seems like my engine is struggling to make RPMs. any advice is welcome.
Old Aug 8, 2023 | 04:04 PM
houm_wa's Avatar
Faults? Codes? Icons?
What is the "E shift?"
If your engine isn't making RPMs, what is it doing? You put your foot down on the throttle, and the RPMs on the gauge don't go up, but can you hear the engine revving up? If not, does it die out?
Old Aug 8, 2023 | 08:24 PM
loanrangie's Avatar
I assume you mean command shift to manually change gears, apart from getting codes next step would be checking the auto fluid level and or doing a fluid change.
nixnorris
Mar 5, 2022 11:12 AM
sjewell
Sep 12, 2019 11:55 AM
gman21
Feb 18, 2013 02:40 PM
DROVER1984
Dec 12, 2012 09:29 AM
RabbiCP
Jun 4, 2011 12:39 PM
