Snow and best setting??
Old Nov 23, 2024 | 05:17 AM
von horst's Avatar
Default Snow and best setting??
Hi all! I have a Disco 3 TDV6.
Well here in Sweden we was taken by surprise, the snow came and with that ice and slippery roads of course! Now what would be the best setting considering I have summer tires ( changing to stud-tires in a week)
would it be "Low" or the snow-setting using the little wheel next to the Low setting?...anybody?
thanks beforehand!
Old Nov 23, 2024 | 05:51 AM
kajtzu's Avatar
I think standard is fine, really, if driving in normal built up areas. The gas pedal has more positions than on and off…😂
You can try the Grass-Gravel-Snow terrain response if you have trouble getting moving. In high range it starts with second gear and response to gas pedal is slightly more hesitant rather than immediate.
I'm now in my 4th or 5th year of driving all year round with traction tires (Pirelli Scorpion AT+) and I rarely bother with any programs. I had studded tires before that. Studs are better on ice, they cut down on braking distances for sure.
There is very little you can do if you’re having summer tires in the winter, however, except have situational awareness and assume braking distances are long. And if driving into a curve the possibility of going in the direction of the tangent.
Mvh
Old Nov 23, 2024 | 08:32 AM
Gnomadf's Avatar
Grass-gravel-snow works fine, but the LR3 is the best vehicle I've ever driven on ice and snow. Better tires do help more than terrain response.
I do miss studded tires. When we lived in Alaska we had a set of Hankook RW11 winter ipikes studded up on a Mercedes ML320 and those tires stuck to the road like a velcro cat. When we moved to Michigan I had to pull the studs, not allowed here, but those tires still worked well enough to put a set on my LR3. When we got the other LR3 for the wife, there were none to be found so we settled for Blizzaks and they were not as good as the Hankooks. Unfortunately the RW11's don't seem to be available any more.
But yeah, studs on ice. Studs work so well that I used to stud my motorcycle tires and ride through the winter. Some people complain that they damage roads, I was not so sure they really did. They definitely keep you out of the body shop.
Old Nov 24, 2024 | 03:02 AM
von horst's Avatar
Yes by Law! we have to change to winter tires the 1:st of December! and here in Sweden most of us living in the country use studded tires! this time however we got taken by surprise! heay snowfall, gusting winds and very cold! most of ud didnt have time to put on the winter tires!
Old Nov 24, 2024 | 05:04 AM
kajtzu's Avatar
I think you’re allowed to drive with 3PMSF marked tires over there just like in rest of EU nowadays. M+S isn’t sufficient anymore, however.
Old Nov 24, 2024 | 08:31 AM
Gnomadf's Avatar
I recall the long lines at the tire shop on the first snow day. I always tried to keep a set of winter tires handy for that reason. I'd have thought the Nordic countries might have snow already....it's snowing here. Not much but more coming. I'm ready!
Old Nov 25, 2024 | 02:55 PM
houm_wa's Avatar
I would also strongly suggest using Lo-Range if you will be traveling on surface streets at speeds less than 30-35 MPH (~55 kilometers per hour). The reason I suggest this is the engine braking. You really don't need to touch the brakes if you're in Lo. Perhaps with the Diesel engine it's less of an issue but with the Petrol engine it really helps. I also turn HDC off.
Old Nov 27, 2024 | 05:15 AM
von horst's Avatar
Sure we have snow, lots of it but mainly up north, down here in the south we've been spared untill now! but it will come and plenty of it! bloody hate it really, I'm a Londoner but living here and it took years before I got used to these harsh Winters: Minus 20 is no unusual temp! horrible!
Old Dec 8, 2024 | 10:59 AM
Gnomadf's Avatar
We got some good snow here and I've tried it with normal and GGS, and GGS dumbs down the throttle to the point of severe annoyance. I do now remember why I loved this beast in the snow, better than the 6G bronco by far.
guy
LR2
Dec 19, 2021 10:36 AM
DiscoBenjamin
Nov 12, 2015 09:26 PM
twaszak
Dec 28, 2012 01:11 AM
DiscoBenjamin
Dec 17, 2010 11:38 AM
Cheska
Jan 9, 2008 03:39 PM
