Sorry for yet another EAS question
Old Apr 28, 2020 | 08:20 PM
mirepoixmatt's Avatar
Default Sorry for yet another EAS question
My EAS has always been an adventure but I was able to get my car to rise. I decided I’d tinker w the front valve block after seeing some videos of rebuilding them. I took her out... opened her up and found some crusty stuff. I cleaned her up and put some new o rings on and voila! She’s on bumps. She will not raise for the life of her. I jumped the relay and the compressor does go on but that’s about it. What have I don’t sweet Jesus what have I done....
Old Apr 28, 2020 | 09:09 PM
houm_wa's Avatar
I would double-check that you out the hoses on the valve block correctly. I hear that's an easily-made mistake.
Old Apr 29, 2020 | 07:12 AM
Thinking back - the only way to screw that up
woukd be to to put the black hose on backwards. Pretty sure the lower hose had the sticker on it but I’ll go back and check. Or do you mean the mechanical connection of the hose is often done incorrectly ?
if so - would you explain ?
Old Apr 29, 2020 | 10:59 AM
houm_wa's Avatar
I only know what I've read on this board; @DakotaTravler would be able to provide details. My understanding was just getting the hose connections backwards (i.e. the "in" hose where the "out" hose is supposed to go, and vice-versa).
Old Apr 29, 2020 | 06:59 PM
DakotaTravler's Avatar
hour_wa is spot on, the hoses can get mixed up. Two black and one green if I recall. And FYI that green one is actually the driver side bag not the input as some think. Gernally only two can get messed up since the lower, which might be the green one, has a 90 it in. So it can only go in one spot. Also make certain you connector is snapped in all the way. I had an issue with mine when off roading. Apparently I did not have it seated all the way from work done months earlier.
Old May 1, 2020 | 08:54 PM
loanrangie's Avatar
If the gunk you cleaned out was a white powder i'd be servicing the compressor and cleaning out the lines and other valve blocks.
beengel
Mar 21, 2009 07:45 PM
stevey88
Feb 24, 2009 03:38 AM
beengel
Feb 23, 2009 05:56 PM
wizardmagu
16
May 16, 2008 09:48 PM
Malafax_Dand
Apr 3, 2008 04:24 PM
