Special programs not available....Special programs off....
Old Aug 28, 2022 | 11:47 AM
yelxuhf's Avatar
Default Special programs not available....Special programs off....
Have had the suspension, and the flashing low gear dash lights on for some time. Also, the trans shifts sticky 2-3,(I suspect stuck shift solenoid). Have checked the TCCM, it looks good, no corrosion, both on the connectors, and opened it up, clean on the inside.
Have replaced the brake switch.
Am getting no codes!!
The raise lower switch doesn't work while driving(vehicle will raise on its own when running and in park!, and then won't lower), niether does the low/high switch, and this switch is flashing.
When attempt to engage the special programs, get "unavalaible"...followed by "Special programs off" dash messages.
Any ideas? Sounds like the TCCM, is there a way to test it? Do have the Gap tool.
Thanks in advance....
Old Aug 28, 2022 | 03:23 PM
houm_wa's Avatar
To me it sounds like both switches are fouled, probably due to spilled liquid in the past.
Old Sep 5, 2022 | 10:33 PM
enb54's Avatar
Check your electrical grounds to the ECU, you might get lucky like I did...
TRIARII
Mar 7, 2018 10:36 PM
Ada2016
Jun 10, 2017 01:06 AM
CarolinaRovin
Mar 23, 2016 02:46 PM
kdscott100
Apr 15, 2014 12:41 AM
