Steering issues, suspension problem level set to normal
Old Jun 10, 2015 | 01:40 PM
caymandrew's Avatar
Default Steering issues, suspension problem level set to normal
Hi Guys,
Have a friend here with an LR3 and he having the above issues, steering is very difficult or what I would say as "choppy". Suspension is giving an error that says it's being set to normal.
I'm a Disco 2 guy so this is a whole new animal for me. Any advice on where to start?
Old Jun 10, 2015 | 01:45 PM
unseenone's Avatar
Can we get more background on what is happening when this occurs. Suspension would be on "normal" when operating on normal highway conditions.
items that come to mind, are sensors, tires, air suspension or components and power steering fluid / pump, bushings, etc.
Old Jun 10, 2015 | 02:14 PM
caymandrew's Avatar
If I start the car up I can raise the suspension level. Once I start driving within a minute it will "Suspension Error, setting to normal"
Power steering fluid is good, could be the pump. But this air suspension I have no clue where to start
Old Jun 10, 2015 | 04:52 PM
threalassmikeg's Avatar
Look at the steering shaft u joints. one is probably frozen causing it to bind.
An off center steering wheel, (where the calibrated steering angle sensor value is off)
can cause a suspension fault to normal after driving.
Old Jun 10, 2015 | 05:40 PM
unseenone's Avatar
The lower one Mike? QMN500250
Old Jun 10, 2015 | 05:56 PM
caymandrew's Avatar
Thanks guys. Can anyone post a link to the service manual for the LR3?
Old Jun 10, 2015 | 05:57 PM
caymandrew's Avatar
How does one go about centering the steering wheel?
Old Jun 10, 2015 | 06:22 PM
caymandrew's Avatar
Which U Joint are you talking about in this image:
Also, Are there any grease point on those U joint?
Old Jun 10, 2015 | 06:41 PM
unseenone's Avatar
#5 is the one I listed, wait for Mike he's the authority. No, LRX has no grease fittings. The lower joint have an issue with some play, that's why i changed mine.
Old Jun 10, 2015 | 07:01 PM
caymandrew's Avatar
Would this be the replacement part? It look like it comes with the shaft:
Land Rover Lower Steering Column Range R Sport 06 13 LR3 LR4 New QMN500250 | eBay
