Steering issues, suspension problem level set to normal
Old Jun 10, 2015 | 07:14 PM
unseenone's Avatar
emailed you a better deal from someone else, that's over MSRP.
I have the old one in a box in the garage, I can snap a picture of it. Make sure that's the item from therealassmikeg
Old Jun 10, 2015 | 07:39 PM
caymandrew's Avatar
one other thing, I notice he still has the RED coolant in his system. That's a huge NO NO on disco 2's, same for the LR3?
Old Jun 11, 2015 | 05:18 AM
threalassmikeg's Avatar
this is the shaft with ujoint
Steering Column Shaft Lower W/U Joint (Genuine Part # QMN500250 ) - Land Rover steering from Atlantic British
Is the steering wheel off center? You can try to center it when you replace the steering shaft.
otherwise the sas can be calibrated using sdd, or an alignment shop may have a sas reset tool that can calibrate it.
You should really scan the vehicle for codes to make an accurate diagnosis
I really have no idea whats wrong, just guessing...
superkev
Oct 10, 2014 04:57 PM
Four Engines and Counting
Feb 28, 2013 09:48 AM
thehun
Jan 28, 2011 09:03 AM
Manicoti
Jan 23, 2011 09:22 AM
EstorilM
Oct 20, 2010 09:40 AM
