stock high sensor rods
Old Dec 16, 2017 | 04:48 PM
packkratt's Avatar
Default stock high sensor rods
The rubber on the rods for the hight sensors is starting to break, I have already "fixed" one, but its only a matter of time before another failure,
Does anyone have a set of stock ones (maybe after an upgrade to lift rods)
Old Dec 17, 2017 | 01:33 PM
houm_wa's Avatar
I think they are pretty cheap even at the dealer parts Dept...front or rear?
Old Dec 20, 2017 | 08:04 PM
packkratt's Avatar
Ill have a look, I have not been able to find a p/n for just the rods, they seem to come with the sensors
Old Dec 20, 2017 | 10:05 PM
houm_wa's Avatar
....back in the day when it was a thing to buy them and make rods, the fronts could be purchased by themselves but the rear required you to buy the sensors.
...not a bad idea to have a few extra sensors on hand, anyway.
Old Dec 21, 2017 | 08:56 PM
DakotaTravler's Avatar
You can order entire sensor kits for under $100 form the U.K. if need be. Part #LR020534 is for the updated 3-pin kit. Included all four sensors.
Old Feb 26, 2018 | 08:14 AM
ZacLR's Avatar
Hi,
I'm looking for height sensor stock rods (for all 4 wheels), I have a 2006 LR3 which had been upgraded with Johnson rods and I need to install the original stock rods back (will change the tires too). do you have any idea where I can find these? I don't want to be the whole sensor assembly.
Thanks,
Zac
Old Mar 11, 2018 | 09:25 AM
packkratt's Avatar
Just to close this out, I ended up by ordering some adjustable rods from
Green Oval Experience info, tyres, off road training
Very happy with them, they were easy to install, and more importantly easy to adjust when needed, I used them on a far northern offroad trip this month and they worked a treat
Old Mar 13, 2018 | 04:37 AM
loanrangie's Avatar
I have a set of these in the glovebox waiting to be used in anger, i should really put them on even in stock height to get used to switching.
KlamathMatt
Apr 17, 2020 05:27 AM
packkratt
Dec 10, 2017 11:45 AM
er1c
Dec 2, 2016 08:40 PM
mouse
Nov 18, 2014 05:20 AM
kgrab
Nov 12, 2010 04:48 PM
