Strange Front End Noise
Old Dec 28, 2024 | 01:36 PM
Hydronaut's Avatar
Default Strange Front End Noise
Just though I would see if anybody has any ideas before I pull the wheel of and check everything.
Seems to happen primarily when turning right but happens randomly when driving, even when in neutral.
Does not seem to be affected be affected by braking.
Wheel bearing?
Old Dec 28, 2024 | 04:09 PM
Hydronaut's Avatar
Originally Posted by Hydronaut
https://youtube.com/shorts/PDqWrft98...Uru3Rlen6dU%0A
Wheel bearing?
Jacked up and right wheel bearing has play. Inner CV also has a little play.
Old Dec 30, 2024 | 08:29 PM
DakotaTravler's Avatar
CV will have play. The noise could be bearing, do both sides if you can as they often fail pretty close together. But check you lower and upper ball joints, the noise sounded more like a ball joint than bearing.
Old Dec 31, 2024 | 07:38 AM
Hydronaut's Avatar
Checked again and the joint itself has no play so actually looks good. Bearing is wobbly and shot. Plan on doing both. Better safe than sorry. Thanks for the reply.
Egg Banjo
Aug 30, 2023 10:00 AM
Dirtking
Jan 31, 2023 03:16 PM
aljameela
Sep 1, 2022 05:25 PM
KernowDiscovery
May 30, 2014 10:44 PM
pickps
May 14, 2007 12:42 PM
