Stuck LR3 hitch
Old Oct 19, 2017 | 03:56 PM
RAJOD's Avatar
Default Stuck LR3 hitch
Its been stuck for like 2 years. I admit I did not try very hard to get it off so I just left it on as I was towing often enough to just leave it.
But now I'm thinking the snow plow LR3 hitch might make it hard to get the spare tire out.
So Today I read up on which way to turn the key to unlock it and which way to turn the green pull out lever.
- Turn key - Clockwise to unlock (Key can't be removed in this position)
- Pull out green **** and turn it counter clockwise (tip downward)
I hit it up and down like 20 times with a large rubber mallet and NO GO!
I don't want to hit it so hard I bust the green lever but I did hit it pretty hard.
Ok whats next?
- Would putting a jack under it to remove pressure help?
- Can this thing put taken apart while on the truck?
- lube it? I don't see too many areas to lube its all sealed.
Any ideas?
Old Oct 19, 2017 | 04:59 PM
houm_wa's Avatar
Yeah I'd lube the interface itself...like spray a bunch of PB Blaster where it slides in (between the tongue and the hole I guess....no jokes!) and then wait a day, do it again, then try to remove it.
Old Oct 20, 2017 | 09:15 AM
djkronik57's Avatar
Wow, does the hitch really block the spare tire? That seems like a poor design decision.
+1 for PB Blaster
Old Oct 20, 2017 | 06:30 PM
RAJOD's Avatar
+1 for PB Blaster
They have two version of the clip on hitch receiver.
- Short on (probably wont block spare)
- Long on that sits lower, it sort of angles back and 2" of it is over the edge of the spare. You could not drop the spare straight down, the edge of tire would hit it. And if the spare is not out of that slot it would need to be tilted at and agle to clear it.
So yea it will make it harder to get spare out, maybe impossible have not tried yet.
The original spare was not a full size, it was a tiny junk tire that I used one time. It was worn out after only a few miles of use.
After that I bought a real LR rim like my others and a new tire and had shop put it back under it. Then I put tow hitch on.
No flats since.
https://www.google.com/search?q=LR3+...HLGpj4WP1r6mM:
I have that one. My Land Rover dealer installed it all when I purchased. But they did not ask me which tow receiver I wanted there was no choice. So they gave me the snow plow version (lower one).
Below see how it blocks edge of spare?
https://www.google.com/search?q=LR3+...HeJXAkMfzWuEM:
Old Oct 20, 2017 | 06:45 PM
If you figure it out let me know I have one stuck in place to
Old Oct 20, 2017 | 10:11 PM
RAJOD's Avatar
Yea I will. Its goofy way they made it. You have a steal (not stainless) big pin that holds it. Its going to corrode where it meets the housing and when you try to retract it it can get stuck easy. And that little green handle offer no real leverage. I've not had one apart so don't know what I'm doing just yet.
There is a metal plate on opposite side of the green ****. It has a set screw. Wonder if that allows access to the insides for lubrication?
Old Oct 21, 2017 | 12:17 AM
RAJOD's Avatar
A bit of a pain in the **** but I found this for you.
Hitch operation and rebuild - Land Rover Forums : Land Rover and Range Rover Forum
I might have to do that.
Old Oct 21, 2017 | 04:08 PM
Yeah I have seen that one mine won't come apart like his did. I have actually had vice grips on mine trying to work the pin loose with no luck.
Every other day or so I give it a shot with PB Blaster and keep hoping lol
Old Oct 23, 2017 | 01:48 PM
RAJOD's Avatar
I'm not sure how he was able to hammer on the pin from under the truck.
There is not much room. I would have to remove the spare tire (if possible)
then find the pin and maybe get a punch and hammer. But then I would need to hold the green handle pulled out or it would be in Locked position.
two man job probably.
Old Oct 23, 2017 | 03:55 PM
I got a punch on mine with no luck
