Sunroof drain
My sunroof drain is leaking and the water runs down the rubber hose behind the pillar trim and has soaked my passenger floor. I have pulled both from seats amp and bracket and tomorrow I plan to pull the center console. What else will need to come out to get the front carpet out so I can get it dried out?
Not sure you need to get the carpet out all the way in order to dry it. I shoved a blow dryer behind it and yes it took time but it did eventually get dry. Also, make sure you get the drains fixed first!
