sunroof drain, driver's side
Old Dec 20, 2014 | 08:33 PM
ljdiscovery's Avatar
Default sunroof drain, driver's side
I reviewed the sticky for the sunroof drains. It was very helpful, to a point It appears that the drain on our lr3 comes down to the ninety bend up under the footwell. The ninety looks like it rotted out and pulled out of the hole in the body. Is there anything, ie another hose, on the back side of the body panel that the ninety plugs into? i couldn't find anything behind it. I pushed in a section of hose and guided it into the hole, the water was draining directly into our footwell. By draining the water through the hole will it drain out of the body? Thanks Phil
Old Dec 20, 2014 | 09:17 PM
TOM R's Avatar
I believe from the pics it just dead ends at the 90
There's pics in the fender vent stickey
Old Dec 21, 2014 | 06:20 PM
mx468's Avatar
If you go to the dealer they have a newer beefier upgraded ninety bend.
Old Dec 29, 2014 | 05:29 PM
DavC's Avatar
You're correct, as soon as that tube clears the hole in the body, it ends. As long as you can get the water from the drain tube out of that hole where the 90 degree bit fit into, then you're fine.
post42
Sep 10, 2013 03:33 PM
Princess
Sep 15, 2009 08:02 PM
mburnett
Jun 5, 2008 09:18 PM
mburnett
Mar 21, 2008 11:38 AM
BlueDisco
Feb 19, 2007 02:50 AM
