Sunroof Leak/Water Ingress
Google search shows leaks from
sunroof drains clogged
A pillar covers
Hvac drains clogged
Passenger door seal
Windshield not glued in correctly
Hvac intake cowel shield fell off
Hole in sunroof drain hose
A pillar covers
Hvac drains clogged
Passenger door seal
Tom thanks for the pictures - I do agree that it looks as if something snapped to the face of the hvac intake there.
As far as your a pillar alignment pegs being broken off - I'm pretty sure a dealer actually performed the TSB on your vehicle. They are supposed to cut off those pegs flush, and use included adhesive seals to cover the hole. When I popped mine off the seal was basically flaking away (great land rover..) but someone had already done the TSB. Also I believe there should be the TSB yellow trim snaps with foam seals on each unlike the factory ones.
Hey Tom mine had a water leak on the driver side and passenger side. My fix was to get a new cowl because mine was warped. I also placed a cover over the air inlet for the cabin filter which was directly below where my cowl was warped, Here's a link to what I constructed... DISCO3.CO.UK - View topic - No more water ingress/passenger side...possibly
The drivers side was a ripped elbow where the water drained from my sunroof. It is located below the hood release latch on the driver's side.
