Sunroof leaks what to check
Old May 8, 2020 | 11:52 AM
Default Sunroof leaks what to check
As some may have seen in my build thread I have some water ingress issues. Aside from the drain lines on for the sunroof what else should I be looking at for possible issues? Especially while the headliner is out and access is good.
I have contemplated just sealing the sunroof permanently but figured I would give repair a try lol
Old May 8, 2020 | 10:16 PM
KMET's Avatar
Amazon Amazon
sealing the sunroof permanently has crossed my mind every cloudy day.
Old May 8, 2020 | 10:30 PM
Wonder how bad that is to install
Old Nov 28, 2021 | 03:11 AM
wichipong's Avatar
warped cowl?
Old Nov 28, 2021 | 09:32 AM
The leaks were up at the roof line so the cowl was not the likely culprit
Old Nov 28, 2021 | 01:38 PM
DakotaTravler's Avatar
Does the LR3 use the same seal? That comes up for for RR Sport, etc.
Also good thread on that seal. I have a ton of wind noise, so if this seal can help I would do it.
https://www.rangerovers.net/threads/...f-seal.175641/
Old Dec 7, 2021 | 01:34 AM
Alex J's Avatar
FYI, that seal is just for wind noise when the panel is closed, it will not seal out water, the edges of the seal are felt and have no way of making a water tight seal. If I decide to keep my LR3 long term I'd probably look into a full metal roof like most of the ROW spec vehicles have. I don't like all the light/heat the glass lets in and the metal roof vehicles have a higher roof load capacity.
Gerard
Feb 21, 2011 02:03 PM
Gerard
Feb 20, 2011 06:54 PM
BigRed98
Jun 21, 2010 12:30 AM
Spencerfitch
May 3, 2010 01:23 PM
marlymarl
Apr 12, 2010 02:00 PM
