Suspension fault
Old Jan 25, 2024 | 04:22 PM
Dizzydog1's Avatar
6th Gear
Default Suspension fault
Hi guys I have a LR3 L319 2006 auto s,
suspension fault normal ride height only,
Originally height sensor right rear was faulty which I replaced and cleared the fault and recalibrated, also did a harness check to each sensor to the body control module all good but now, soon as I start the car no fault can change the height to extend and down to lower ride height all smooth, as soon as I drive 2 meters then the message pings up suspension fault normal ride height only, after extensive checking with my diagnostic tool an icarsoft v3.0 the only fault that shows is 1. Unused relay (permanent) I have checked all the relays with a relay checking device all good, so I'm pondering if my air suspension control module is at fault, or any one here may know of what this unused relay means as nothing comes up on Google search or the land rover training program that iv got, it's got me stumped. Any ideas would be appreciated.
Old Feb 11, 2024 | 04:19 AM
Dizzydog1's Avatar
6th Gear
Default Update all sorted
Hi guys found out what the Fault was asides from the amk compressor failing which I replaced it turns out the control system switched my suspension system to manufacturing calibration setting which put the red light on my dash soon as I turned it to normal operation al faults are cleared and now have full use of my suspension.
Old Feb 12, 2024 | 12:04 PM
johnsonmc2000's Avatar
Thanks for the answer. We all know someone will have the same one day. I see you're in Swindon. I'm from Tisbury but live in California now. I do miss the Wiltshire countryside.
CTrover767
Nov 21, 2021 02:54 PM
Ken@stricksbbq.com
Mar 28, 2019 07:10 PM
Morgan1281
Mar 10, 2016 02:10 PM
jaguardoc504
LR4
Jan 16, 2016 12:26 PM
PeterOZ
Feb 3, 2013 08:04 PM
