Suspension Fault - Intermittent
Old Jul 30, 2018 | 01:29 PM
wichipong's Avatar
Default Suspension Fault - Intermittent
I've been getting a suspension fault (none specific) alert while driving a few hundred miles, shut the car off and start it again issue goes away. everything seems to be fine... anything i need to look at? please advise.
Old Jul 31, 2018 | 01:01 AM
houm_wa's Avatar
Can't advise without knowing what the fault code states. Buy yourself an IIDTool from GAP Diagnostics and you'll be able to do that.
Old Aug 10, 2018 | 01:38 AM
wichipong's Avatar
Code C1130-66 Air Spring Air Supply - Intermittent
Any ideas?
Old Aug 10, 2018 | 09:29 AM
abran's Avatar
Sounds like a leak.
put vehicle in off road height, any hissing sounds?
if not, measure all 4 corners and disable EAS(fuse or battery), remeasure in 12-24 hours.
Old Aug 12, 2018 | 01:46 AM
wichipong's Avatar
Originally Posted by abran
Sounds like a leak.
heard hissing in fdon’t both sides but more noticeable on drivers side. Replace front springs? What else needs to be looked at?
Old Aug 12, 2018 | 05:37 AM
loanrangie's Avatar
Soapy water in a spray bottle and look for the bubbles on airbag and around the hose connection.
Old Aug 24, 2018 | 11:01 PM
wichipong's Avatar
How do I test the front valve block and see if that is the culprit?
Old Oct 26, 2018 | 12:35 AM
wichipong's Avatar
Replaced air suspension compressor as it went bad. Still need to replace front driver side air spring assembly. Need suggestions on where best to buy and if I replace just the leaky one or both fronts at the same time.
Old Oct 26, 2018 | 05:34 AM
abran's Avatar
Both, in a non air ride vehicle you would never change out one shock.
Old Oct 26, 2018 | 09:36 AM
COSPILOT's Avatar
Dealer was positive I had a leak and suggested I replace all four corners. I replaced the compressor and all 3 valve blocks instead. So far so good. It can sit for week with only about a 1/4" drop.
