Suspension Issues
Old Dec 3, 2012 | 09:15 PM
lr32nv's Avatar
Default Suspension Issues
I have a 2006 LR3 which has been giving some suspension faults for the past few months. I had the compressor replaced about a month ago and the faults have continued. This week I noticed that the right side was sitting lower than the left.
Took it to the shop and was told that there was an "air articulation" fault and another for the left rear height sensor. The service guy stated that the air articulation fault was caused by me as I had recently done the rear brakes and did not properly support the axle. Basically all he had to do was reset the suspension system and that would take care of that.
Now the problem that I'm having is that the faults are gone but the rear of the truck is sitting way lower than the front. Even if I put the truck in "off raod" mode, the rear suspension will raise but never leveled with the front.
Does anyone know what could cause this? Like I said rear and front raise and lower properly but not leveled. Thanks in advance!!
Old Dec 5, 2012 | 04:37 PM
Rovin4life's Avatar
dumbass, the height sensor code tripped the cross articulation fault. Its not the brake job its the damaged height sensor or the wiring or both.
nijones25
Apr 27, 2011 11:38 PM
kalmdude
Dec 26, 2009 09:31 AM
MLAWSO16
Feb 18, 2008 07:29 PM
ckwgreb77
Jan 31, 2008 09:29 AM
gno242
Nov 29, 2006 11:37 AM
