Suspension Lowering When Parked
Old Nov 16, 2017 | 09:21 PM
AJ1's Avatar
AJ1
5th Gear
Default Suspension Lowering When Parked
After parking for 5 hrs or so, my LR3 is "settling" a bit. Once I start the engine, it rises in about 10 seconds to the mid level (correct height) pretty quickly. My air pump historically often runs a bit after I start the car, however the "lowering" after parking is new. Is this a setting or a leak? Surprised that is rises so quickly to the right height after I start. Thinking that a leak would take longer to level. Thoughts?
AJ
Old Nov 16, 2017 | 09:38 PM
houm_wa's Avatar
Sounds pretty normal to me, unless it's "settling" all the way down to bumpstops.
Old Nov 19, 2017 | 07:22 PM
uoflcardfan77's Avatar
It's settling to what is called entry height. Makes it easier for us short people to climb into these monsters.
Old Nov 20, 2017 | 09:19 PM
AJ1's Avatar
AJ1
5th Gear
Any idea why it is just starting now? I would say it is lowering a few inches. In that past it would level a bit from time to time. Nothing like it is doing now. I can even tell the difference when parked. Is the suspension leaking? Or is this a setting? Thanks.
Old Nov 20, 2017 | 09:40 PM
djkronik57's Avatar
It could be one of the valve blocks. The suspension auto-levels, so if one corner leaks air and drops, you won't know it because the whole truck will be lower. Find the auto-leveling fuse and pull it after you've put it up to off-road height and parked it somewhere you can leave it for a few days (or overnight). Measure the center of the wheel to the fender on each corner and then come back and measure again (or it might be blatantly obvious). A single corner dropped is usually a leaking strut. Both front or both rear is usually a valve block leaking. I think there's one more mode of failure where it can leak back through the system and all 4 drop, but not clear on what the culprit is. That'll at least point you in the right direction.
Old Nov 21, 2017 | 02:36 PM
Well at first you said "a bit" then "a few inches". If it's the few inches then listen to what dj said.
Old Jul 26, 2019 | 08:23 AM
alexla's Avatar
My range rover sport supercharged 2007 120.000 km lowers when parked about 1,2 cm every night . I have put out the buttery for 48 hours and the lowering is about the same in every corner total about 2 ,5 cm at every corner . The land rover official service in athens tell me that i must change all the air suspensions and the air compressor . Total cost 7.500 euro . Unbelievable !!! Any idea what could be the problem with my vehicle ?
Old Jul 26, 2019 | 09:11 AM
abran's Avatar
Put in in off-road height , shut off and get outside. Stick your ear in each fender well and listen for leaks.
if you don’t hear any, then it’s guess time. I would start with front valve block. Then test again.
Old Jul 27, 2019 | 12:46 AM
alexla's Avatar
Thank you abran . I will try this .
Old Sep 9, 2019 | 12:46 PM
ADEBEE007's Avatar
Default Suspension Lowering on Rear Left Side When Parked
My LR3 2006 is settling to the bumpstops on the rear left about 30 minutes to an Hour after I park. What could be the possible cause?
